No signs of life on Hp Omen 16 gaming laptop
My laptop is an Hp omen 16 RTX 3050 i5 12500h 16gb ddr5 ram 60hz screen.
I was using my laptop last night but noticed that the display flickered 2-3 times for a short while but everything else was working fine. I was able to watch YouTube, open photoshop and do some work as well as run rpcs3 and pcsx2 just for a quick 30minute gaming session.
I wake up the following morning and try to resume as normal but my display turned blue and I saw the BSOD that said video display error and my laptop shut off. It boots into the locksreen and then I hear audio glitch and then it boots off. That happens 2-3 times until eventually it boots into recovery mode. That’s when I chose to uninstall the latest windows update and did a system restore on the 4th February 2024.
I booted into windows and noticed that my RTX graphics aren’t being shown in device manager. I used the Hp omen gaming hub to try force my laptop to use discrete graphics. I try reboot again and then my laptop literally just went off and never turned on again.
I checked the power supply is working when I use it on my other Hp laptop that I have. There’s no signs of life, no orange peer indicator, completely nothing. Tried to remove the battery and plug the power in but nothing. Held the power button for 2 min with battery plugged in and out but nothing.
I just noticed that when I plug the charger in my omen and then plug it in my Hp laptop. It doesn’t charge the Hp laptop until I pull it out from the socket and plug it back in.
What could be the issue?
Es esta una buena pregunta?
Could the charger be defective. Does your other HP have a charger and do they have the same specifications?
I would be suspicious of the GPU if it is not listed in the Device manager. Can you get into the BIOS screen?
- de mike
