Why it became hang
my pc become slower than before it hang alot
Es esta una buena pregunta?
If your computer has been freezing/hanging a lot, there could be several causes. You may want to start with checking on how much space is left on your drives. If any of your drives are almost full, this can cause slower, worse performance, which can be solved by clearing some space on the drive. Before deleting files to free space, check to see if you have a second slot for an additional SSD (Solid State Drive). This will add more space.
Another reason could be due to a hard drive. These are mechanical, so they perform slower than modern SSDs. If you still have a mechanical hard drive, I recommend replacing it with an SSD.
Hope this answer helps your freezing/hanging problem. :)
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 7
Todo El Tiempo: 67
