Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Mi teléfono se mojó
Mi teléfono se mojó y no enciende
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Acude a un service de telefonia movil y que evaluen si es reparable y que se ha de sustituir, en la mayoria de telefonos mojados, el daño, es irreparable ya que la bateria sulfata y quema las placas electronicas
Fue útil esta respuesta?
Puntuación 1
@mauricioaqu2596 the answer by my esteemed colleague @carloslope27326 is absolutely correct. However, I am one of those people that loves to tinker and does not like to give up on devices. This is what I would do, since there is nothing left to lose.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since iFixit does not yet have a guide for this phone, use something like this video Next remove the main board, the battery and the charging board. You will have to remove all the EMI shields. The shields are most commonly soldered to the board but can easily be removed. If you do not remove the shields, you are not cleaning the boards.
Take a close look at all components and connectors. Assess the damage carefully. Look for major corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
Do not use compressed air for the cleaning since that can drive liquid as well as corrosion particles into areas that will cause trouble later on. You do not need to leave the boards to dry. Isopropyl alcohol in the higher concentration will evaporate quickly and dissipate the water.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now. In all seriousness I would also replace the daughter board. It is relatively inexpensive and replacing it will eliminate any issues with it later.
After all of that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@mauricioaqu2596 la respuesta de mi estimado colega @carloslope27326 es totalmente correcta. Sin embargo, yo soy de esas personas a las que les encanta trastear y no les gusta renunciar a los dispositivos. Esto es lo que yo haría, puesto que ya no hay nada que perder.
Por ahora, debe dejar de intentar cargar, sincronizar o utilizar el teléfono. Esto potencialmente puede empeorar una mala situación. Esto puede dañar aún más su teléfono.
El primer paso que yo tomaría es desmontar el teléfono. Desde iFixit aún no tiene una guía para este teléfono, utilice algo como este video A continuación, retire la placa base, la batería y la placa de carga. Tendrás que quitar todos los escudos EMI. Los escudos son más comúnmente soldada a la placa, pero se puede quitar fácilmente. Si no quitas los escudos, no estás limpiando las placas.
Examine detenidamente todos los componentes y conectores. Evalúe cuidadosamente los daños. Busque corrosión importante, evalúe las clavijas de los conectores, etc. Revise todos los conectores y los extremos de los cables. Una vez que haya limpiado toda la suciedad, utilice alcohol isopropílico al 90% y limpie las piezas un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero todos los pasos siguen siendo pertinentes a su teléfono también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza.
No utilice aire comprimido para la limpieza, ya que puede conducir líquido, así como partículas de corrosión en las zonas que causarán problemas más adelante. No es necesario dejar secar las tablas. El alcohol isopropílico en mayor concentración se evaporará rápidamente y disipará el agua.
Lo importante aquí es la limpieza. Por supuesto, lo mejor sería limpiarlo con ultrasonidos No se olvide de cambiar la batería. Esto es una obligación y no una opción. Fallará si no se ocupa de ella ahora. Con toda seriedad yo también reemplazaría la placa hija. Es relativamente barata y reemplazarla eliminará cualquier problema posterior.
Después de todo eso, volver a montar el teléfono y volver a evaluar. Mientras no hayas limpiado la placa y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si estuvo expuesto durante 2 segundos o 2 horas, lo que importa es dónde el agua (partículas) hizo el daño.
Mientras trabajas con el teléfono, haz muchas fotos. Una vez que haya terminado con él, tomar esas fotos y crear una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Puntuación 0
Añadir tu respuesta
Mauricio A. Quiirós estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 14
Todo El Tiempo: 210
