Problema al cargar de mi teléfono a 13
No se escucha en llamadas
Es esta una buena pregunta?
@leo16891 your question is confusing. If you have trouble with the charging then there are a few things you need to check. First you want to check your charger. Make sure it has the proper voltages. Next check your charging cable. Check to make sure the connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If all of that checks out okay, the issue can be related to your charging board as well as the flex cable from the charging board to the main board. Always check and change the battery as well. If after all of that your phone still does not see the charger, the issue will be on the mainboard. For that you will need somebody with board level repair experience. Hopefully replacing the charging board, flex cable and battery will resolve this issue. For the charging board, you are looking at something like this It is available at many online stores. Since iFixit does not yet have a guide for this, use something like this guide to work on your phone.
Now, if people can't hear you on a call, the issue could be the mic. First place your phone in safe mode and try using the microphone. If there is no problem in Safe Mode, it may be a problem caused by a third-party app on your phone. To find which app is causing the issue, uninstall one after the next. OF course you can also try the hardware diagnostics by dialing *#0*# It is here that you can do the mic and speaker test.
IF it has failed, replace it. Here is the one part. The mic and the charging issue could be related to the same board since the mic is soldered to the charging board (daughter board).
So, replacing that board may fix both issues.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@leo16891 tu pregunta es confusa. Si usted tiene problemas con la carga a continuación, hay algunas cosas que usted necesita para comprobar. En primer lugar usted quiere comprobar su cargador. Asegúrese de que tiene los voltajes adecuados. A continuación, compruebe el cable de carga. Asegúrate de que los conectores no estén doblados, etc. A continuación, comprueba el puerto de carga. Límpialo de suciedad, etc. Utiliza un poco de aire para limpiarlo. Si todo esto está bien, el problema puede estar relacionado con la placa de carga, así como el cable flexible de la placa de carga a la placa principal. Siempre revise y cambie la batería también. Si después de todo esto el teléfono sigue sin ver el cargador, el problema estará en la placa base. Para ello necesitará a alguien con experiencia en reparación de placas. Esperemos que la sustitución de la placa de carga, cable flexible y la batería va a resolver este problema. Para la placa de carga, usted está buscando algo like this Está disponible en muchas tiendas en línea. Como iFixit todavía no tiene una guía para esto, usa algo como esta guía para trabajar en tu teléfono.
Ahora, si la gente no puede oírte en una llamada, el problema podría ser el micrófono. Primero coloca tu teléfono en modo seguro e intenta usar el micrófono. Si no hay ningún problema en el modo seguro, puede ser un problema causado por una aplicación de terceros en el teléfono. Para averiguar qué aplicación está causando el problema, desinstala una tras otra. Por supuesto, también puedes probar el diagnóstico de hardware marcando #0# Es aquí donde puedes hacer la prueba de micrófono y altavoz.
Si ha fallado, reemplázalo. Aquí está la parte. El micrófono y el problema de carga podrían estar relacionados con la misma placa ya que el micrófono está soldado a la placa de carga (placa hija).
Por lo tanto, la sustitución de esa placa puede solucionar ambos problemas.
Mientras trabajas en tu teléfono, toma muchas fotos. Una vez que haya terminado con él, tomar esas fotos y crear una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 4
Ultimos 30 días: 16
Todo El Tiempo: 215
