Saltar al contenido principal
Repair guides and disassembly information for Oppo‘s Realme Android smartphone line.
¿Podrías ayudarme con un oppo a15?
Tengo un oppo a15 pero de la nada dejo de cargar y sólo aparece ⚡ este icono al cargar pero en color rojo, ya probé con loa cabes de carga pero no hay resultado, podrías ayudarme con este problema en el equipo, gracias
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
@alex27000 that can have quite a few causes. you need to check your charger to make sure that it works. Since you already checked the charging cables, we can rule those out. Next you need to check the charging port. Make sure that there are no bend, broken or corroded pins. Clean it out with a few puffs of compressed air. After that, you will have to disassemble your phone.
Your phone uses a separate charging board, I would go ahead and replace that as well as the battery. Check the flex cables going from the charging board to the main board. Make sure that it is not damaged or corroded.
After that you can only try a factory reset or ou may have issues on the main board with the charging IC. LEt's see if we can rule out everything else first.
Since ifixit does not yet have guides for this, use the one from here Replacement boards and batteries are readily available on many online stores.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Translation
@alex27000 que puede tener bastantes causas. usted necesita comprobar su cargador para asegurarse de que funciona. Como ya has comprobado los cables de carga, podemos descartarlos. Lo siguiente que tienes que comprobar es el puerto de carga. Asegúrate de que no hay clavijas dobladas, rotas o corroídas. Límpialo con un poco de aire comprimido. Después, tendrás que desmontar el teléfono.
Su teléfono utiliza una placa de carga separada, yo seguiría adelante y reemplazar eso, así como la batería. Compruebe los cables flexibles que van desde la placa de carga a la placa principal. Asegúrese de que no está dañado o corroído.
Después de que sólo se puede tratar de un restablecimiento de fábrica o ou puede tener problemas en la placa principal con el IC de carga. Veamos si podemos descartar todo lo demás primero.
Dado que ifixit aún no tiene guías para esto, utilice el de aquí Las placas y baterías de repuesto son fáciles de conseguir en muchas tiendas online.
Mientras trabajas con el teléfono, haz muchas fotos. Una vez que hayas terminado con él, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://es.ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Puntuación 0
Como cambiar el micrófono
Puntuación 0
2 comentarios:
Como cambiar el micrófono de mi celular oppo
- de
Sacar cuenta binario 5 a15 ?
- de
Añadir tu respuesta
Alex estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 4
Todo El Tiempo: 224
