Changed rear master cylinder now even after bleeding I stillDon’t have
Replaced rear brake cylinder now even after bleeding I have no pressure 2010 Silverado rear wheel drive
Es esta una buena pregunta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 1
Todo El Tiempo: 26
2 comentarios
Found out that the new cylinder blew out Not understanding why this happened.
- de richard fritts
If by new cylinder you mean a wheel cylinder inside the hub of a set of drum brakes then most likely you did not adjust the brakes properly after you repaired/replaced the wheel cylinder. The brake shows were allowed to spread far enough so as to let the new cylinder come apart.
- de Thomas Stigall
