Saltar al contenido principal
Google Pixelbook Go es una Chromebook premium de Google que cuenta con una carcasa de magnesio duradera y un diseño minimalista. Lanzada en 2019. Número de modelo: GA00521-US.
removed bottom lid and tore orange ribbon
I ripped the orange ribbon that attaches to the battery and the motherboard. the computer is basically new and all else is good. I was just to careless and pulled the lid off too hard and at an angle and ripped. is it unrepairable?
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
From my poking around the dark corners of the internet, it appears that orange cable is part of the battery itself. I saw no indication at all that the cable can be purchased by itself, and there were no pictures showing how it connects to the battery, as it goes under a glued-on cover before making connection.
So really, the only hope here is that if you uncover the connection and find that it's some sort of plug connector, then you could probably replace it, assuming you can locate that flex cable. I had zero luck finding it, so to be honest I strongly suspect you're going to have to replace the battery to recover from that particular mistake. Here's the iFixit guide showing you how to replace the battery.
Google Pixelbook Go Battery Replacement - iFixit Repair Guide
Unfortunately, the batteries on that Chromebook aren't cheap; most of them I saw were running right around the $100 USD range, making this a somewhat expensive error, sorry to say. Here's a typical example; you may be able to find something cheaper with an extensive search on places like Amazon, eBay or AliExpress.
USA 100% new Genuine 7.64V 47.4Wh B50 battery For Google Pixelbook Go 13.3" - eBay
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
jerrry estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 15
Todo El Tiempo: 146
