@srgravet just to add to the excellent answer given by my friend and colleague @carloslope27326
Rice does not work. It does absolutely nothing to help you with this repair. All it does is waste time and waste food. Check here https://www.ifixit.com/News/30047/rice-i... for more on this.
For now, you must stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your phone. Since ifixit does not yet have a guide for this phone, use something like this video to help you disassemble your phone. Remove the main board and the charging board. You will have to remove all the EMI shields. If you do not remove the shields, you are not cleaning the board. PErsonally I would replace the sub board (daughter board or charging board)
Take a close look at all components and connectors. Look for any corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your phone as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your phone and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
Translation
@srgravet sólo para añadir a la excelente respuesta dada por mi amigo y colega @carloslope27326
El arroz no funciona. No ayuda absolutamente en nada en esta reparación. Lo único que hace es perder el tiempo y desperdiciar comida. Consulta aquí https://www.ifixit.com/News/30047/rice-i... para saber más sobre esto.
Por ahora, debe dejar de seguir tratando de cargar, sincronizar o utilizar el teléfono de otra manera. Esto potencialmente puede empeorar una mala situación. Esto puede dañar aún más su teléfono.
El primer paso que tomaría es desmontar el teléfono. Dado que ifixit aún no tiene una guía para este teléfono, utilice algo como este video para ayudarle a desmontar el teléfono. Retire la placa principal y la placa de carga. Usted tendrá que quitar todos los escudos EMI. Si no quitas los escudos, no estás limpiando la placa. PErsonalmente yo reemplazaría la placa secundaria (placa hija o placa de carga).
Echa un vistazo a todos los componentes y conectores. Busque cualquier corrosión, evaluar los pines en los conectores, etc,. Echa un vistazo a todos los conectores, así como los extremos de los cables. Una vez que haya limpiado cualquier contaminación, utilice alcohol isopropílico al 90% y limpie las piezas un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero todos los pasos siguen siendo pertinentes a su teléfono también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza.
La importancia aquí es la limpieza. No se olvide de cambiar la batería. Esto es una obligación y no una opción. Fallará si no te ocupas de ella ahora.
Después, vuelva a montar el teléfono y evalúelo de nuevo. Mientras no hayas limpiado la placa y sustituido la batería, todo son suposiciones. Tenga en cuenta que los daños por agua son los más difíciles de localizar y reparar. No importa si se expuso durante 2 segundos o 2 horas, lo que importa es donde el agua (partículas) hizo el daño.
