My speaker left audio jack not working
Es esta una buena pregunta?
I'd recommend trying to isolate the issue and ruling out some easy fixes. I've detailed a few things to check below:
If all of that fails you might need to replace the headphone or audio jack. Unfortunately, Apple soldered the audio jack to the motherboard so if you want to do a DIY repair you most likely will need to replace the entire board. Alternatively, you can find a local repair shop that is skilled in microsoldering so that they can perform the repair for you. Alternatively Alternatively, if you feel confident, you can attempt to microsolder the replacement yourself.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 3
Todo El Tiempo: 28
