Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
El iPhone convencional de Apple de 2020 se lanzó el 23 de octubre y viene con una pantalla OLED de 6,1", un sistema de cámara dual de 12 MP y en cinco colores disponibles. Sucesor del iPhone 11.
Logo comes on than off, nothing happens, need to disconnect bat
A client came in saying the screen turned black, I tried new screen and new battery, logo comes on once and then off, any thoughts ?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
3 Respuestas
Respuesta Más Útil
disconnect front flex and check again, if that doesnt work try disconnecting the charge port
Fue útil esta respuesta?
Puntuación 1
1 comentario:
When I tried a new screen I did not transfer the front flex, that illuminates it. I will try disconnecting the charge port.
- de
If possible, a reset of the phone will work or if not possible due to possible data loss connect it to your windows computer and use itunes to restore the device by clicking the "Restore" option or if you have a mac use itunes on older versions or simply use finder on newer models.
Puntuación 1
7 comentarios:
So I tried disconnected the flex for charging port, if I did it right its the one just beside the battery connection, still nothing. Reconnect everything and plug to lap top and it doesn’t even recognize it, like if it was completely dead.
- de
Hi @sylvaincvei5277
it appears the problem is not the screen, it may be the power. Have you located where the power is going using a power meter? Depending on where the power ends that's the broken part
Cheers!
- de
Not much experience testing, I don’t have a power meter, just a multi meter. Any help on how to test would be greatly appreciated.
- de
Hi @sylvaincvei5277
Since you do not have a power meter and just a multi meter, it works as well. You're just checking for where power is going.
- de
Ok so I have a power meter hooked up and the amp measured is .4amps looks too low but not sure the specification I am suppose to have?
- de
Mostrar 2 comentarios más
is an error 9 check about it online
Puntuación -1
1 comentario:
How do you know its error 9 ?
- de
Añadir tu respuesta
SYLVAIN C VEILLEUX estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 8
Ultimos 30 días: 30
Todo El Tiempo: 456
