Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Procesador Intel de doble núcleo modelo A1502 / 2.4, 2.6 o 2.8 GHz / Lanzado en octubre de 2013
I cracked screen. Not charging or green light on screen.
I dropped my Mac book Pro A1502 late 2013 and the screen cracked. At first there was power but blurry/lines on screen. Then the battery went dead and now will not charge. There is no green light on power cord. Bought a new power cord but still nothing. I’ve opened it up and when I attach the power cable the fan turns on for a few seconds then stops. Do I simply need to replace screen or is there another problem with power?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Not that simple! Yes you do need a new display, but you need to troubleshoot the logic board as well as you clearly have a deeper issue.
Consider the costs and your skills. If you don’t have the knowledge to read a schematic and using the common test tools as well as access to the components and tools to replace them it might be better to seek out someone who does.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Lucky7 estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 6
Todo El Tiempo: 122
