Saltar al contenido principal
A1418 / EMC 3069 / 2017 / Procesador i5 de cuatro núcleos a 3.0 GHz, 3.4 GHz o i7 a 3.6 GHz de cuatro núcleos. Lanzado el 8 de junio de 2017.
Hard Drive and Blade Flash Drive upgrade
Hi.
Can I upgrade the 1TB HDD and the 32GB Flash storage in my iMac 21.5" 4K Retina 2017?
I am opening up the iMac to upgrade the RAM & HDD to SDD and would also like to upgrade the 32GB Flash storage with OWC Aura Pro X2 SSD
I will be running MacOS Ventura 13.6 and I believe the Firmware combines the 2 Drives into 1? I intend to install the OS on the new SDD and leave the OWC aura-pro-x2-ssd for use as explained in https://en.wikipedia.org/wiki/Fusion_Dri...
Im unsure if I'm on the right path as there are a lot of conflicting advice.
Thank you
John
Imagen de Replace or upgrade the PCIe solid-state drive in a variety of Macs.
Producto
OWC Aura Pro X2 SSD
$119.99
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
1 Respuesta
Hey there,
Regarding the hardware you've chosen, you should be on the right track. I'll also link you to iFixit's recommended RAM and secondary SSD upgrade kit. You should be completely fine if you've got your macOS Ventura installation image ready.
Imagen de Max your iMac Intel 21.5" EMC 3069 (Mid 2017, 4K Display) with 32 GB RAM. Upgrade bundle includes all the parts and tools needed to mod your iMac.
Producto
iMac Intel 21.5" EMC 3069 (Mid 2017, 4K Display) Memory Maxxer RAM Upgrade Kit
$189.99
Imagen de Upgrade the storage and improve boot time and read/write speed in your iMac Intel 21.5" Late 2012-2019 with this SSD upgrade kit.
Producto
iMac Intel 21.5" (Late 2012-2019) SSD Upgrade Kit
$89.99
Fue útil esta respuesta?
Puntuación 0
1 comentario:
My main concern I would appreciate advice on is upgrade of the 32GB Flash storage with OWC Aura Pro X2 SSD?
And I would prefer to go with an Internal SSD rather than an External SSD as is would be less prone to failure and I will the iMac fully torn down
Any advice would be appreciated
John
- de
Añadir tu respuesta
John Loch estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 3
Todo El Tiempo: 75
