Saltar al contenido principal
My Kindle oasis is frozen with an updating screen
My kindle oasis is frozen with an updating screen. I tried holding the power button for 40+ seconds. But it's not doing anything. Anybody else encountered this problem and found a work around?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Your model S8in4o is 10th Generation.
Your battery may be very low. Try charging it for a few hours and then try resetting it again.
Failing that work try disconnecting the battery, press power botton, which will force a "cold boot". Then reconnect battery, reassemble - yes I know but take your time, Look at 6:13 in video linked below:
Replace Battery
Fue útil esta respuesta?
Puntuación 1
1 comentario:
I charged it (light is green) but no luck resetting. BTW, for resetting im holding down the power button for 40 secs. The model number is S8in4o.
- de
It happened to me because I used it in the swimming pool (underwater....) and next week started to frozen and finally didnt respond.
I put it in a dehumidifier (it can be a single sealed box with a dehumidifying tablet that you can buy for ~€2/$2) and leave it for at least 48 hours, and now It works again
(the first few minutes it may be a little slow, but then it will be fine, like the first day).
Do not do as other people say of using a hair dryer, it can even be dangerous (the back is made of aluminum, so it can hurt your hand when it is hot, like it happened to me :-( )
Good luck!
Puntuación 0
Añadir tu respuesta
Ollie estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 5
Ultimos 30 días: 16
Todo El Tiempo: 311
