Saltar al contenido principal
Mando PS4 modelo CUH-ZCT1. Lanzado en noviembre de 2013 por Sony Computer Entertainment, este controlador de batería de iones de litio de 3,7 V y seis ejes no es complicado de reparar. (NOTA: la guía de desmontaje NO es para este modelo)
Preguntas 20 Ver todo
Wired Connection not working
I have a ds4 controller that works via Bluetooth but is unable to work with a wired connection to the PlayStation and pc. I figured the port wasn’t working so I decided to swap the port with another controller whose analog sticks are broken. This new port works perfectly but when making the swap, the controller still doesn’t show up as a wired connection.
I can provide pictures or answer any questions to help troubleshoot this issue. At this point I’m more intrigued on how to get it working than anything else. Any hardware that I should be looking at that could be the culprit here?
Worth noting: Since the wired connection wasn’t working, i decided to download ds4windows to see how the Bluetooth connection to the pc would hold up vs input lag. During this process, I was changing settings on ds4 along with the controller device in my pc control panel. I disabled a driver that a video recommended during this. Not sure if I might have done something to alter the controllers ability to recognize the wired connection.
Thank you!
Update (01/07/24)
This has been solved. Needed to get the correct usb connection for the controller model. Ordered this online and now the controller works fine.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
@lincolnabe0978 copy your update as an answer, then accept it. That way we know it has been resolved.
Puntuación 1
Añadir tu respuesta
Brad Riley estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 5
Ultimos 7 días: 23
Ultimos 30 días: 86
Todo El Tiempo: 1,013
