Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Intel Core i5 de doble núcleo a 1,8 GHz (Turbo Boost de hasta 2,8 GHz) con 3 MB de caché L3 compartida
Would A1466 EMC 2632 be compatible with A1455 EMC 2559?
I am trying to fix my dad's laptop [MacBook Air 13" Mid 2012 - A1466 EMC 2632] from unexpected shutdowns, I took it to a store and they told me I needed a new logic board. I found the Item # IF188-177-1 [MacBook Air 13" (Mid 2012) 1.7 GHz part but I am not sure if it is compatible since it lists [EMC 2559] Could someone guide me a bit more before for me before I purchase it? You time is very much appreciated.
Imagen de Replace a 1.7 GHz logic board (motherboard) compatible with the Mid 2012 MacBook Air 13" model laptop. Fix processing issues like unexpected shutdowns, reboots or water damage.
Producto
MacBook Air 13" (Mid 2012) 1.7 GHz Logic Board
$79.99
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Let’s take a deeper look at the EMC numbers
So other than the year these are the same system A1496. We reference parts at the Model ID level here MacBookAir5,2 & MacBookAir6,2 in this case.
Fue útil esta respuesta?
Puntuación 0
@carolinaurr9246 double check your dad's laptop. From what you are giving us (A1466 EMC 2632) that would make it a mid 2013 not a mid 2012. The logic board for that computer is a 820-3437. For the EMC2559 that number will be 820-3209.
If it (your dad's laptop) is a 2012 (double check your numbers :-) then the logic board you selected will fit. If it is a 2013 it will not. The 2013-2017 are interchangeable but not to the 2012 due to the heatsink and connector location etc.. It will not fit.
A1455 is a iPad Mini and no, that logic board will definitely not fit ;-)
Puntuación 0
Añadir tu respuesta
CAROLINA URREGO RAMIREZ estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 6
Ultimos 30 días: 9
Todo El Tiempo: 180
