Saltar al contenido principal
Guías para la versión Wi-Fi del iPad mini 5: modelo A2133. Lanzado en marzo de 2019, el iPad mini 5 es el sucesor del iPad mini 4.
Digitizer not working after replacement
I bought a replacement Screen and digitizer The screen works great but the digitizer docent some spots don't register on the left and right in portrait mode and in regular mode I can't see ANY damage The connector looks good. Is there Something you have to cover or is it apple's prioritization
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
don't have the original screen but the old digitizer worked perfectly except it was cracked and the display
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
You didn't mention if you had cleaned the connector with some 90% or higher isopropyl alcohol, but other than that it looks to me as though you've covered pretty much all of the diagnostic bases.
At this point I would communicate with the seller of the replacement screen on the issues you're having with it and see about getting a replacement, especially given that you didn't have digitizer issues with the original screen.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
thanks I cleaned it am waiting for it to dry. let you know if it works.
- de
Añadir tu respuesta
Alistair moran estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 157
