Saltar al contenido principal
en mi caso se apagó luego de nadar en la piscina
Buenas tardes, en mi caso se apagó luego de nadar en la piscina. Al cargarlo, aparece un mensaje que dice "data not cleared" y no carga.
¿ Que puedo hacer ?
Muchas gracias
Atte.
Sergio
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@sergi80550 since this happened after water immersion, this is what I suggest.
For now, stop to try to charge, sync or otherwise use your Versa. This potentially can make a bad situation worse. This may further damage your phone.
The very first step I would take is to disassemble your Fitbit. Since ifixit does not yet have a guide for this phone, use something like this video to help you disassemble your phone. remove the main board.
Take a close look at all components and connectors. Check for any sign of corrosion, evaluate the pins in the connectors etc,. Take a look at all connectors as well as cable ends. . Once you got any gross contamination cleaned, use 90%+ isopropyl alcohol and clean your parts some more. For a proper cleaning, use this guide. It was written for an Apple iPhone 3G but all the steps are still pertinent to your Fitbit as well. I can not stress the importance of a good cleaning enough, so do it over and over while replacing the alcohol after each cleaning.
The importance here is the cleaning. It would of course be best to get it ultrasonically cleaned Do not forget to replace the battery. This is a must and not an option. It will fail if you do not take care of it now.
After that, reassemble your Fitbit and re-evaluate. For as long as you have not cleaned your board and replaced the battery, everything is just a guess. Keep in mind that water damage is the hardest to troubleshoot and to repair. It does not matter if is was exposed for 2 seconds or 2 hours, what matters is where the water (particulates) did the damage.
While you work on your Fitbit, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
@sergi80550 ya que esto sucedió después de la inmersión en agua, esto es lo que sugiero.
Por ahora, dejar de tratar de cargar, sincronizar o utilizar de otra manera su Versa. Esto potencialmente puede empeorar una mala situación. Esto puede dañar aún más su teléfono.
El primer paso que yo tomaría es desmontar tu Fitbit. Dado que ifixit aún no tiene una guía para este teléfono, usa algo como este video para ayudarte a desarmar tu teléfono. retira la placa principal.
Echa un vistazo de cerca a todos los componentes y conectores. Compruebe si hay algún signo de corrosión, evaluar los pines en los conectores, etc,. Echa un vistazo a todos los conectores, así como los extremos de los cables. . Una vez que haya limpiado cualquier contaminación gruesa, utilice alcohol isopropílico al 90%+ y limpie las piezas un poco más. Para una limpieza adecuada, utilice this guide. Fue escrito para un iPhone 3G de Apple, pero todos los pasos siguen siendo pertinentes para su Fitbit también. No puedo enfatizar lo suficiente la importancia de una buena limpieza, así que hazlo una y otra vez mientras reemplazas el alcohol después de cada limpieza.
La importancia aquí es la limpieza. No se olvide de reemplazar la batería. Esto es imprescindible y no una opción. Fallará si no te ocupas de ella ahora.
Después, vuelva a montar su Fitbit y evalúelo de nuevo. Mientras no hayas limpiado tu tablero y reemplazado la batería, todo es sólo una suposición. Tenga en cuenta que los daños causados por el agua son los más difíciles de localizar y reparar. No importa si estuvo expuesto durante 2 segundos o 2 horas, lo que importa es dónde el agua (partículas) hizo el daño.
Mientras trabajas en tu Fitbit, haz muchas fotos. Una vez que hayas terminado, toma esas fotos y crea una guía para iFixit. Eso ayudará a la próxima persona que tenga el mismo problema que tú. Es fácil y divertido crear estas guías. https://ifixit.com/Guide/new La comunidad iFixit lo agradecerá.
¡Reparar es la guerra contra la entropía!
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Sergi estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 0
Todo El Tiempo: 54
