How to repair the microphone
Es esta una buena pregunta?
Hi Abdoo,
First of all, we would need to know which microphone it is you're having trouble with. There are different ones for use when you're talking on the phone versus filming a video, for instance.
The lower microphone is located on the auxiliary board at the bottom of the phone. If it has failed then you would need to replace the board. Sorry to say that iFixit doesn't have a guide showing you how to do that repair, but there's a Spanish site called Nadie Me Llama Gallina that has just what you need.
Manuales / Huawei Mate 20 lite / Auxiliary plate
The Nobody Calls Me Chicken site has a link to a site in Spain that sells the part, but you can easily find it on sites like Amazon, eBay and AliExpress, among others.
PREMIUM Auxiliary plate PREMIUM with components for Huawei Mate 20 Lite (SNE-LX1)
If it's the other microphone, as nearly as I can tell it appears to be mounted on the motherboard, so you would most likely have to replace the motherboard in order to fix it. That's one you should definitely do more diagnostics on to be sure that's the problem before going to the drastic length of replacing the motherboard. However, if you end up needing to, here's the guide showing you how.
Manuales / Huawei Mate 20 lite / Motherboard
I was actually surprised to find that the motherboard is readily available and wasn't actually all that expensive. Here's one site that had it; an internet search will bring up several more.
Good luck with your repair; let us know what you find.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 11
Todo El Tiempo: 57
