Saltar al contenido principal
El refrescado tan esperado del popular Mac mini. Las opciones de procesador incluyen 3,6 GHz de cuatro núcleos Intel Core i3, 3,0 GHz 6 núcleos Intel Core i5 y 3,2 GHz 6 núcleos procesadores Intel Core i7.
The status indicator light is on once connected to power
My mac mini i7 cannot send video signal to monitor (black screen). I found the indicator light will immediately on (white) once I connected this Mac mini to power. Press the power button for 10 seconds, I can turn off the Mac min and the light also turned off. the light will be on if unplug and replug in .
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
2 comentarios
Have you tried anything specifically yet to fix this? This could be as simple as a bad cable. How are you connecting your Mac to the monitor?
- de
I have two Mac mini, the other one is i5 I used the same hdmi cable. mini i5 is working well. I connected this working min i5 to the same power supply, the indicator light won't turn on until I press the power button.
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Given your symptoms I’m suspecting the I/O logic within the CM246 platform controller has failed, I’ve seen this before as the video wake line still functions which is what you are seeing.
Sadly, this system will need a new logic board.
Fue útil esta respuesta?
Puntuación 1
2 comentarios:
Thanks, Dan. Could you tell me the name of logic board and where I can find it ?
thanks,
- de
@yuan24263 - This series has soldered storage, as such each version has a different P/N. Review this listing to find the one you either have now or if storage is a bit thin jump up to a larger version. 2018 Mac Mini Logic Boards
- de
Añadir tu respuesta
yuan estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 9
Todo El Tiempo: 190
