Need help to find missing pad p13USB
Hello i need help to find where this pad go on the motherboard
the 484 pad on the p13usb thank you for your help
Es esta una buena pregunta?
Here the solution
Confirmed the DP2 signal pair do not go anywhere. So do the other pair DP3 pair signals (pin8&9) on V2 consoles go nowhere. Took me awhile to confirm because they do go somewhere on the OLED. The values found are internally in the PI3USB chip where they are pulled down by 100k each line. If you were to remove all components off the board, I expect that to be open to GND.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 50
