Why is my engine cooling water reduce rapidly?
why is my engine cooling water reduce rapidly?
Es esta una buena pregunta?
@abelsitotaw check for a leak on the cooling system. Consider all hoses, the reservoir as well as the radiator. If you are not losing it then there is the possibility that your engine is burning it due to a bad head gasket or even a cracked block. Check your spark plug faces and see what they look like. Also heavy white smoking exhaust is indicative of that as well.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 9
Ultimos 30 días: 38
Todo El Tiempo: 159
