Saltar al contenido principal
Can't regulate heat
Cannot regulate the heat
Update (11/23/23)
Whirlpool Model ACE244XSO The heat will vary 10+ degrees------ up and down without moving the thermostat setting. Probably the thermostat but I haven't found one for it.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario
Hi @calvinwiles,
What is the make and model number of the Air Con unit?
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
Hi @calvinwiles
There are two thermostats in the air con unit, Item #10 and #31 airflow and control parts diagram
Temperature control thermostat Item #10 is part # WP1185753 (supplier examples only).
Item #31 is part # 4388458 but I can't find any online. This one looks more like a safety cutout thermostat for the heater given its location, rather than a room temp control thermostat like Item #10. If you suspect it is the problem, check if there's a different part number on it or a make and model number and search online using that information
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Calvin Wiles estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 112
