screen isn't turning on after replacement
wont turn on after screen replacement
Es esta una buena pregunta?
Is the original screen still in a sort of working condition so that you reinstall it to check if the problem is due to the replacement display or on the systemboard?
If not, it may come down to board level testing using the service manual to find out what's wrong.
I couldn't find a free download online, you may have better luck.
Fue útil esta respuesta?
Hi @michelle51666,
See Step.51 of the ifixit Reemplazo del conjunto de batería y pantalla del Samsung Galaxy S22 guide
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 14
Todo El Tiempo: 84
Hi @michelle51666,
Have you checked if the display flex cable is securely connected?
- de jayeff
sm 901 and I had it all apart and put it back together everything seems in place an tight
- de michelle
i think so im no pro at all tbh i have no idea what im doing i watched alot of youtube so idk if i even know which flex cable that is
- de michelle
