Saltar al contenido principal
Laptop empresarial de 15,6 pulgadas de Dell que ofrece durabilidad, capacidad de administración y seguridad lanzada en 2010.
Preguntas 3 Ver todo
How to upgrade graphics card on this laptop- Latitude E6510
Hello I am unable to find info on how to upgrade the graphic card on this laptop or if it is even possible. I am trying to upgrade it enough so I can play red dead on it. I already upgraded to 16gb ram and a ssd as well a i7cpu so the next thing i would need is a good graphics card and maybe a wifi card upgrade as well. I just cant find any info on how to upgrade these items. according to steam to best run red dead 2 i need at least this graphic card (Nvidia GeForce GTX 1060 6GB / AMD Radeon RX 480 4GB) if any one could point me in the right direction it would be much appreciated.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
Hi Erick,
I'm afraid you've run into the biggest limitation that laptops have versus desktop machines; the lack of upgradeability. Sure there are some features you can swap out to help with performance like HDD and RAM, but in order to fit everything into a laptop case, it all has to go onto the motherboard. Which means there isn't a separate graphics card that can be changed out; all you have is the graphics hardware, including the graphics chip (NVIDIA NVS 3100M) all built into the motherboard. Sometimes you can swap out the motherboard for one with more capabilities, but that depends on the manufacturer making two different motherboards that fit into the same chassis. Sometimes they do that, but it's more the exception than the rule and I see no indication that there's anything else available for yours.
So yeah, the short story is that there's no graphics upgrade possible for your laptop that will give you what you're looking for. If you want upgradeability like you're thinking you have to go to a desktop machine; laptops just don't have it.
Fue útil esta respuesta?
Puntuación 3
Añadir tu respuesta
Erick Hernandez estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 13
Ultimos 30 días: 20
Todo El Tiempo: 253
