Saltar al contenido principal
El nuevo formato de la línea 14 de Apple cuenta con un OLED de 6,7 pulgadas -como el Pro Max- pero con las mismas características que el iPhone 14, con una configuración de doble cámara y el chip Bionic A15 con una GPU de 5 núcleos.
Preguntas 20 Ver todo
Extra part after disassembly, please help!
Hi guys,
I've taken apart my Iphone 14 Plus to put everything in a new housing. unfortunately in the process I've taken something out which I now don't know where belongs. Can anybody please help?
Thanks a lot!
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Solución Elegida
Thanks for the input @flannelist. Some very close inspection of teardowns helped me to find the location. It's something between the speaker and the charging port part. I've attached a picture below. Phone all working now! Thanks!
Fue útil esta respuesta?
Puntuación 1
Respuesta Más Útil
I have not worked on one of these yet. But Apple loves little bits like these. It looks like an antenna of some kind. Based on the way its shape I would wager it goes into the side of the housing somewhere, like a button flex. My first through would be the NFC antenna which is usually in the sidewall of the housing near the rear camera. But I haven’t been able to pin down the location for sure.
Here’s a pretty in depth teardown for the 14 Plus on a top down view. You might be able to find the placement based on this.
https://youtu.be/QlkC6_AiinU?si=9s53xDZB...
Puntuación 2
Añadir tu respuesta
Michael Buijs estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 2
Todo El Tiempo: 114
