Saltar al contenido principal
Procesador Intel Core i7 de cuatro núcleos a 2,2 GHz (Turbo Boost de hasta 3,4 GHz) o 2,5 GHz (Turbo Boost de hasta 3,7 GHz) con 6 MB de caché L3 compartida.
Why does my bootcamp assistant not show this option?
When following the tutorial to install windows 10 in my 2014 macbook pro i7, I opened the bootcamp assistant app and then was going to choose the windows iso but I looked at the video and then looked at my mac and saw a completely different screen showing (SELECT TASKS) instead of choose ISO file. If anyone can help that would be great!!
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Solución Elegida
The reason for the Select Tasks page showing up versus what was shown in the YouTube tutorial you found is that your Mac does not support installing windows without creating a USB installer from the Windows ISO which is available on the 2015 and newer Macs. Basically you will need to select all three of the available tasks to continue and you will need an 8GB or larger flash drive. The following step will have you create the bootable flash drive and select the Windows ISO. After the USB drive is created then it will allow you to partition the internal drive for the Windows installation. For a detailed step by step please see Apple's support document here.
Fue útil esta respuesta?
Puntuación 1
1 comentario:
Thank you It helped (:
- de
Añadir tu respuesta
Chase reitelbach estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 9
Ultimos 30 días: 29
Todo El Tiempo: 310
