Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
La Panasonic Lumix DMC-G7 es una cámara de lentes intercambiables sin espejo de nivel de entrada lanzada en mayo de 2015. La cámara tiene una resolución de 16MP y es capaz de capturar video 4K. Los números de modelo son DMC-G7 en la mayor parte del mundo y DMC-G70 en Europa.
None of the back buttons work
Have you found a fix for this? I ran into this exact same problem. Fixed a loose piece in the camera and now the buttons won't work.
Update (10/18/23)
The entire inside element that holds the lens as well as the sensor was loose. So the lens and sensor wiggled around. I took it apart and put in two small screws and that fixed the issue. At work we have 4 G7s, and theyre all slowly giving out.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
1 comentario:
@joelvanbeek same camera Lumix DMC-G7? What part did you fix?
- de
Agregar un comentario
1 Respuesta
@joelvanbeek try the service code on your camera to see if there is an error code. Make sure that after your work on your camera, that both Flex cables are properly re-connected and that the mainboard is free of any corrosion etc. Also make sure that you check the connectors for the flex cables. Remove the cables and then restart them. Check the ends for any tears etc. Here is the SM Panasonic DMC G7 that will help you with the diagnostic as well as the service for your camera. Let us know what you find.
There is of course always a possibility that this is Firmware related, but check the parts etc. first.
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Joel Van Beek estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 18
Todo El Tiempo: 390
