Saltar al contenido principal
A1418 / EMC 2833 / Finales de 2015 / 3.1 GHz Core i5 o Procesador Core i7 de 3.3GHz. Lanzado el 13 de octubre de 2015.
Preguntas 20 Ver todo
iMac Airport driver causing CPU panics, antenna looks rusted?
As you can see in the photo, the Wifi antenna looks discolored, almost rusted. The rest of the iMac looks fine, just the normal dust. The Wifi works a bit, will connect to 2.4 but says the password is wrong on 5Ghz networks (it's not). The iMac will restart randomly with an Airport driver as likely suspect. I'm thinking of removing the board and just using a USB dongle but was wondering if anyone had any thoughts on what's going on here. Thanks in advance!
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
I would replace the antenna unit as it’s possible it’s shorting out.
As far as a USB dongle I think you’ll have a hard time finding one. You’ll need an Ethernet to WiFi bridge to connect via the systems Ethernet port. Thaway you can get the full data rate.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
maccentric estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 6
Ultimos 30 días: 6
Todo El Tiempo: 63
