Upgrade to BT 4.2 issue with antenna
Hi guys,
I updated my cMP 5.1 to BCM943602CDP (BT 4.2) but I don't have extension cable for BT antenna so I used different one (from ASUS Vivo PC - please see attached picture). Now I can see that I have BT 4.2 in System Preferences but can't connect any devices unless there are few inches from Mac. But If I take out the side panel the connections is better (the antenna is located on the top of the front CPU 120mm fan).
Q1: Is this just antenna issue ? So I need the extension cable and everything will be OK ? (original bluetooth antenna is located at the end of the Mac but it's look like is attached to the case)
Q2: Is there any differences between BT antenna extension cable and Wi-Fi antenna extension cable ?
Thank you very much for any ideas :)
Es esta una buena pregunta?
