Battery change mAh difference - Will it work?
Hello everyone,
I finally got my 6 year old MSI GE72 2QE up and running again!
The battery was causing issues, so I removed it and now it works perfectly.
So I wanted to get a new battery, so my work won't get lost if I pull the plug or if there is a power outtage.
The battery there was IN the laptop ORIGINAL had 4730 mAH but the ones I see on EBAY is 5200 mAh, will there be any consequences with the difference in the mAh, since there also is a slight difference in the Volt and Ah (amps)
I am using below universal charger:
100-240V
2.2A - 50-60 Hz
19V - 7.89A
The original battery:
4730 mAH
51 Wh
10.86V - 4.73Ah
Replacement battery1:
5200 mAh
48 Wh
10.8V
Replacement battery2:
3834 mAh
41.40 Wh
10.8V - 3.834 aH
Since money is a bit short, and I want to get maybe one more year out of my MSI, I was thinking that a battery with shipping at 40€ is worth the deal.
Es esta una buena pregunta?
