The saw blade release lever is stuck in the release position.
Blade release lever is stuck in the release position. How do I get it to the locked position?
Es esta una buena pregunta?
Puntuación
0
Ultimas 24 horas: 1
Ultimos 7 días: 10
Ultimos 30 días: 15
Todo El Tiempo: 43
Is this jigsaw clogged with debris? Can you clean off as much debris as possible then try a little WD-40 into the release lever and blade jaw? Some light rapping against the body with a mallet can help loosen dirt buildup with WD-40 loosening up a sticky mechanism.
- de F Dryer
