Saltar al contenido principal
Información de reparación y desmontaje del teléfono inteligente Pixel 7 Pro de Google, lanzado en octubre de 2022. Identificado por el número de modelo GP4BC y GE2AE.
Preguntas 20 Ver todo
Microphone Issues after screen replacement
After I replaced the screen on my pixel 7 pro my bottom microphone must've stopped working, atleast I think it's bottom, I can make phone calls but not use google assistant or any sound recording apps.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 5
1 comentario
have the same problem
- de
Agregar un comentario
1 Respuesta
Respuesta Más Útil
From Reddit; Hello, nothing worked for my 7 pro until I found this work around. Download Voice Recorder & Voice Memos, open the app, and try recording. You can stop recording but dont close the app. The mic will start working. I set the app preference to work in background and never close the app. Then, open the Recorder app. It will start working normally. Transcription works beautifully. All phone apps work normally while Voice Recorder & Voice Memos is open in the background.
BINGO the voice recorder and voice memos fixed my issue, tried all the other crap and none worked. I suspect the app uses the other mics, so may not fix the lower mic issue, but allows one of the other for voice recording. Either way, I can now voice text again, my large thumbs don't fit the small keyboard well. Thanks ReviewTall3533!!!
Fue útil esta respuesta?
Puntuación 2
3 comentarios:
I have same issue. Don't find any solution.
- de
I've tried this. It uses only the camera microphone (above the display), not the lower one that doesn't work since my screen replacement
- de
I have the same probleme. Don't find any solution.
- de
Añadir tu respuesta
NIck Nolan (Double.N) estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 3
Ultimos 7 días: 10
Ultimos 30 días: 44
Todo El Tiempo: 726
