How to replace the compact flash card slot?
My fathers Nikon D300 flash card slot has a pin bent. How do I replace it?
Es esta una buena pregunta?
@jfix8745 it's a bit of a PITA. Use this SM Nikon D300and check for the removal of the CF base plate. Not sure if you can get to the pin but it should be possible. If not I would try and find a replacement for the complete base plate. something like this would work. This is just an example and not an endorsement of the seller.
While you work on your Dad's camera, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 116
