Saltar al contenido principal
El 16/600 PS es una impresora postscript fabricada por Apple.
Why is the paper jamming?
My apple laserwriter is jamming paper in the front behind the toner and in the back help please.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
Ensure your paper is static free. Fluff it from four directions. Try putting a shim in the paper tray under the papers front edge to give it more lift. Often the springs weaken over time and the paper is too low for the grippers to grab. You might roughen/deglaze the pickup rollers with an old eraser or emory board (fingernail file).
If this Answer is helpful please remember to return and mark it Accepted.
Fue útil esta respuesta?
Puntuación 0
Just fixed the same problem on my apple laserwriter 16/600 tonight. The gear that goes from the drive assembly (from the motor and running the front half of the paper flow) to the fuser is on a pivot. Mine was pivoted up a bit, and so wasn't making good contact. It had been making noise for the last 20 prints or so, but then finally lost contact.
Pivoting that gear down, so it contacts the metal gear on the fuser assembly, made it now work.
It seems like there should be a spring holding it in this position, or that the toner cartridge should hold it down. But on mine it doesn't. Unfortunately I spent 4-6 hours figuring this out, and taking apart the printer, before figuring out that the gears just weren't making good contact. But I cleaned out a piece of scorched paper and the 2 sensors on the fuser, and cleaned out 18 years of dust, so something was accomplished.
Puntuación 0
Añadir tu respuesta
sue marais estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 3
Ultimos 30 días: 9
Todo El Tiempo: 1,794
