aux port not working.
After alot of search i couldn't find a guide to fix it.As far as I think it's a electrical problem.
Es esta una buena pregunta?
try and look at devices to see if it is disabled
Fue útil esta respuesta?
@abdullahso19894 why would you think it's an electrical problem. You have not told us what you have checked or what you have tried out. Here is the service manual that will help you to work on it. You will also need to let us know what OS you are using and if you have tried to see if this is possibly a Software issue. Open it up and check that the wiring is still fully connected.
First, you need to determine if it is original.
Second, you need to check if the audio chip is not damaged.
After that, check your aux connection.
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 23
