iPhone 12 mini crash - Panic CPU x caller
Hi guys, after screen (LCD incell iTruColor) and battery replace my 12 mini started crashing randomly.
Trying to explain: take the phone, press power botton, see black screen with only the possibility to see time and date + widget (in white color) on lock screen and background total black. So, phone crash and restart, after that seems to be fine until a new crash in the same way.
It's not a port crash cause it doesn't appen every 3 min, but smth like every hour, less time o more.
I assumed that the cause could be screen or battery, what do u think about?
There's crash report by 3u tool (just first page).
Thanks
{"bug_type":"210","timestamp":"2023-09-28 07:07:21.00 +0200","os_version":"iPhone OS 17.0.2 (21A351)","roots_installed":0,"incident_id":"CE3A7996-04AB-47CF-93B9-573CBC50B703"}
"build" : "iPhone OS 17.0.2 (21A351)",
"product" : "iPhone13,1",
"socId" : "8101",
"socRevision" : "11",
"incident" : "CE3A7996-04AB-47CF-93B9-573CBC50B703",
"crashReporterKey" : "3b3024a3249931b5b9d704c27fdd0e30705bd80f",
"kernel" : "Darwin Kernel Version 23.0.0: Fri Sep 15 13:42:40 PDT 2023; root:xnu-10002.2.12~1\/RELEASE_ARM64_T8101",
"date" : "2023-09-28 07:07:21.00 +0200",
"panicString" : "panic(cpu 2 caller 0xfffffff02aebb374): DCP PANIC - apt firmware: adisp.c:2756 start_frm_active() -- - iomfb_mailbox(65)\napt firmware: adisp.c:2756 start_frm_active() -- \nRTKit: RTKit-2413.2.1.release - Client: local-iphone13dcp.release\n!UUID: f17c9e48-7e13-378c-966e-cb19dd25fad2\nTime: 0x000000004bcedacd\n\nFaulting task 65 Call Stack: 0x0000000000028160 0x0000000000027af8 0x00000000000278fc 0x00000000000206c4 0x00000000000c3970 0x00000000000f282c 0x00000000000f257c 0x00000000000f00b4 0x0000000000028644 0x0000000000023148 000000000000000000\nRTKit Task List:\n name | pri | stack use | status | resource | warning\n 0 rtk_background | 007 | 880\/2048 | SEMWAIT | 0x467c40 | \n 0x0000000000022540 0x0000000000023620
Update (09/29/23)
UPDATE: for the moment phone is on since 1 day without any crash (I've checked reports) so it's maybe a faulty screen.
I'll update when LCDs screens back in stock and let you know if with another screen I will fix my issue.
I will also put some information about if it's worth to replace an oled with an LCD or if I will have some problems.
Update (10/06/23)
UPDATE: got a new display (incell) and everything is fine, so it was just a faulty display.
Es esta una buena pregunta?
2 comentarios
Tagging Alisha (@flannelist) for help with this one; all I've come up with so far is one claim that DCP stands for Display Co-Processor, which would be the graphics chip part of the SOC.
- de Jerry Wheeler
So problem with logic board or could be just a faulty display? I hope the second… and could the fact that I’m using LCD a problem or not?
- de Andrea Castiello
