Saltar al contenido principal
Lanzado en Septiembre 16, 2016. Modelos 1660, 1778. Disponible en GSM o CDMA / 32, 128, o 256 GB / Oro Rosa, Oro, Plata, Negro Mate y Negro Brillante.
Preguntas 2266 Ver todo
Can I swap battery cells 6S to 7?
Long story short I have a 7 that has a battery so dead that the phone won't even detect it anymore. Is it possible that I can take the good cell off of a 6S battery and connect it to the iPhone 7's BMS to make a 'new battery'. It would only be temporary but I don't know if it's possible.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 1
Agregar un comentario
2 Respuestas
Respuesta Más Útil
Actually, I'm going to disagree with @corbanizer and suggest that there's no real reason it wouldn't work. The base chemistry of the battery cells is the same; they both take the same charging voltage at roughly the same rate and the BMS will regulate that. I'm guessing he 6S battery is slightly smaller so it will have a marginally shorter run time, but I doubt it's enough to make a significant difference.
As Corban said, the best strategy would be to simply buy a new 7 battery, but honestly there's no reason your plan won't work. The only catch here could be physical limitations; the electrodes coming out of the 6S cell have to be similar enough in geometry that they can be connected to the 7's BMS, and the physical size has to be such that it will fit into the 7's battery compartment and let the connector plug in.
If you do go ahead with this, be sure and come back and show us pictures of either the process or the finished product and let us know how it worked. Success stories are always appreciated, and we can usually learn something even when things don't go as planned.
Oh, one last thing; the best method for working on batteries is using a spot welder, as it minimizes the heat the battery cell is exposed to. If you don't happen to have one of those little devices, then solder carefully and use as little heat as possible; just get them tacked on so there's a good electrical connection.
Fue útil esta respuesta?
Puntuación 3
3 comentarios:
Currently working on trying this out, so far the hardest part is trying not to be scared of the batteries and getting the BMS out of the adhesive shell they're in. Will keep you posted and thanks for your detailed answer :)
- de
Update: damaged the BMS flex so couldn't continue, ordered a new battery with next day shipping
- de
@keiranmelton Aw rats, I was looking forward to the experiment. Well, at least that'll get you going.
- de
I wouldn't try it. Apple is known to not like that kind of thing and they have compatibility issues. I would just buy a new Iphone 7 battery and do it right the first time. Buy Once, cry once.
Puntuación 0
Añadir tu respuesta
Keiran Melton estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 2
Todo El Tiempo: 55
