My black E7 headphones won't play any sounds
The lights turn on but it won't play any sound
Es esta una buena pregunta?
Hello, after doing some searching, I've found that it may be a bluetooth connection issue. What this means is more than likely an issue with the device you're trying to connect to instead of the headphones. I would recommend checking if all your software is up to date or a simple reset should do. If the problem persists, then I would recommend following this troubleshooting guide. I hope this helps!
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 7
Ultimos 30 días: 15
Todo El Tiempo: 75
