cold battery will not charge where do you buy battery?
will not charge says cold battery
Update (09/25/23)
where do you buy battery for plus one watch
Es esta una buena pregunta?
@frankdidente could be a bad battery. The battery has a temperature sensor, and a failed battery control board can give you that error. Start by replacing the battery.
Check this OnePlus Watch Teardown and see if this is something you would tackle.
Fue útil esta respuesta?
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 9
Todo El Tiempo: 101
Could be a bad temperature sensor.
Li-ion batteries shouldn't be charged below 40 F ( ~ 5 C) so there is a sensor to check for this.
If you warm it up, can you make the message go away?
- de Allen
