Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Una cámara digital de apuntar y disparar de Panasonic identificable en América del Norte por el número de modelo DMC-ZS7
Lumix DMC-TZ10 will not read micro SDHC fitted into SD adapter.
I confess I'm not sure if it is capable of using the micro SD. It works on a normal SDHC card, but throws up the error 'Insert SD card again' or 'Use another SD card' when I use the micro. I've tried formatting (on PC) in FAT32 or NTFS, neither works.
I am unable to format the card in the camera as it will not accept it.
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
2 Respuestas
Solución Elegida
@phil55263 looks like your camera only accepts SD (up to 2GB), SDHC (up to 32GB) or SDXC (up to 64GB) memory cards. It appears as if it does not accept the MicroSD cards. Download the owners manual from places like this Page 9 and on, explains more about this.
Fue útil esta respuesta?
Puntuación 0
What size ( capacity) sd card did you insert? If the camera works with sd-hc, it will only work with 32GB cards ( or smaller).
These days, sd cards are SD-XC. If you shop around, you can still find sd-hc cards.
For example:
https://www.microcenter.com/product/6095...
Puntuación 0
Añadir tu respuesta
phil estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 1
Ultimos 7 días: 5
Ultimos 30 días: 23
Todo El Tiempo: 608
