My charging port is not working
my oppo a53s charging port has an issue the charger cannot fully get inside
Es esta una buena pregunta?
@vitin40128 check the port for any debris or bend contacts. If cleaning it or if the contacts are broken, you will need to replace it. Luckily the charging port is soldered to a charging board. It will be much easier to just change the complete board. You are looking for something like this
iFixit doesn't yet have a guide for this. Use something like this video to get this repair done.
While you work on your drive, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has the same problem as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Fue útil esta respuesta?
Charge is slow. Charge is slow. Charging is delayed
Change charging point
Charging not working
@ladabeshra you did not provide enough information to actually help you. I would suggest the same thing as in my original answer.
Ultimas 24 horas: 2
Ultimos 7 días: 45
Ultimos 30 días: 264
Todo El Tiempo: 1,311
USB port dry and clean and reset phone ka masge a raha ha bar bar
- de Zidi Nuwab
