Why won't my immobilizer light shut down. The car won't start?
When I turn my Renault Clio 2 1.4 on the Immobilizer light is constant on and not shutting down ,thus the car won't start?
Es esta una buena pregunta?
Check if the 2A fuse # 28 in the passenger compartment fuse box is OK.
This supplies power to the Immobilizer read coil, which is near the ignition switch.
The coil reads the codes from the ignition fob key when it is inserted into the ignition switch.
Not sure what you mean but here's an image showing the location of the fuse in the fuse box.
The fuse rating is printed on the fuse itself, but in the image it is covered by the number 28
(click on image)
Be aware that if you replace the fuse and it blows again there may be a problem with the immobilizer reader module or perhaps the wiring to the module
Fue útil esta respuesta?
is it possible to send a photo of the fuse #28?
Ultimas 24 horas: 1
Ultimos 7 días: 2
Ultimos 30 días: 63
Todo El Tiempo: 200
