Door is not opening from outside
My kia sportage door is not opening from outside but it only opening from inside
Es esta una buena pregunta?
@zunairzahid you will need to remove your door panel and check the connecting rod to the outside handle. Either they popped out or the plastic handle broke,. If it is broke , you will have to replace the handle. If it just popped out, replace the rod and secure it.
If your are talking about your power door lock not unlocking it, the it is the lock actuator that needs replacing.
Fue útil esta respuesta?
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 8
Todo El Tiempo: 71
