Stuck at logo screen
barely turns on but getting this when it wants to turn on it started to happen once i changed my trackpad to a new one
Es esta una buena pregunta?
Apparently it was a loose memory that cost this.. im glad it was that instead
Fue útil esta respuesta?
Yeah i ran test on it and everything pass i was confused cus the cpu chip was still in good condition i guess when i replaced the trackpad is loosing the memory didnt notice till now
Ouch! Not good 😩😣😢
The Intel CPU chip set has failed! This series uses the built-in graphics engine within the CPU. What you are seeing is a graphics side failing so the system comes to a standstill!
You might see this physically if you pull off the heat sink you might see one of the two chips cracked.
@djmavstar - mmm the Intel graphics engine does use the main memory for its video RAM so that explains that. I haven’t encountered that condition before so you taught me something new!
Ultimas 24 horas: 0
Ultimos 7 días: 4
Ultimos 30 días: 4
Todo El Tiempo: 29
