Saltar al contenido principal
Softener and Bleach Containers
Water is no longer disbursing the softener and bleach from the containers during the cycle. Any ideas?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Assuming you have manual detergent and softener dispenser:
Does the WM complains about missing water? Do you see an error on the disply Exx (with xx as a two digit number)? Normally there are two water inlet valves and a water diverter. If there is no water coming at all, it would imply you did not open the water tap :-D If the water tap is open, than it sounds like one (or both) water valves does not work. Which can be caused by a lot of things .... (check if there is a kink in the hose).
If you have an i-DOS WM: Is the detergent and softener drawer fully in? Are the metal contacts of the i-DOS drawer clean (remove the i-DOS drawer completely. There are some contacts in the back). Did you overload the i-DOS drawer, so that the both pumps may got defect?). Does the WM shows you missing detergent and softener? (=sensors defect).
Fue útil esta respuesta?
Puntuación 0
Añadir tu respuesta
Stormi Ocean estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 1
Todo El Tiempo: 76
