Saltar al contenido principal
Únete a la Comunidad de Reparación - Crear Cuenta
Modelo A1238 / disco duro de 80, 120 o 160 GB / frontal de metal negro o plateado
Why does my iPod keep booting into diagnostics and wont let me out?
I just replaced my screen and battery on my Ipod and now it keeps booting into diagnostics (which I did and everything is working perfectly fine) and it wont let me out of diagnostics mode.
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Does it boot back into diagnostic mode after a hard reset? Hold the "menu" and center button for ~10 seconds and that should reboot the device.
If that doesn't do it, maybe let the battery die by keeping it in debug mode off of a charger, and see if recharging it gets it to boot up normally.
Fue útil esta respuesta?
Puntuación 0
4 comentarios:
I tried this. It reset, then kicked me back into diagnostics. I tried with battery power, i tried with just wall power with no battery connected, i tries with firewire, nothing. just back to diagnostics.
- de
@catdge You might have to restore the iPod, which will re-install the operating system and hopefully address whatever issue is causing it to boot into diagnostics. There's a decent iFixit guide on this process here: Como entrar a modo DFU y restaurar el iPod
- de
I will try that.
- de
Just note that this will delete all data on the device, definitely the brute force option. If this doesn't do it, it's probably time to re-open the device and check for damage, missing grounds, etc... Something simple like a stuck button or disconnected cable shouldn't cause it to boot into diagnostics.
- de
Añadir tu respuesta
Catdge estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 2
Ultimos 7 días: 14
Ultimos 30 días: 29
Todo El Tiempo: 508
