Como cambiar la memoria a otro dispositivo para recuperar las fotos?
Se mojó un dispositivo y se necesita recuperar las fotos.
Es esta una buena pregunta?
Buenos dias Levi, el problema cuando se moja un telefono, es que se sulfata y quema en la mayoria de casos, el conector de carga,a parte de lo que se pueda dañar en la placa electronica, no es mi intención desanimarte, pero lo que propones es casi imposible que se pueda conseguir, por el daño de la placa, la memoria no es una memoria externa tipo RAM como puede suceder con los ordenadores, en un telefono esta incluida en la placa principal por lo que no es extraible.
Yo no soy tecnico de telefonos moviles, a penas he tocado alguno, esperamos a ver que opinan los compañeros que si tienen experiencia en estos temas.
Fue útil esta respuesta?
@levijosaph68560 You cannot recover any file from your phone unless you get it to start up. Starting it up in the condition it is in will cause further damage. My colleague is absolutely correct,that this is not an easy repair and there are no easy fixes for it. My answer is just another option for you to consider.
For now, stop continuing to try to charge, sync or otherwise use your phone. This potentially can make a bad situation worse.This may further damage your phone.
The next thing to do is to clean it. Disassemble your phone using Samsung Galaxy S21 Ultra these guides . You must remove all EMI shields. If you do not remove those, you might as well not do anything. After you removed those, clean all the boards Main board and charging board, connectors and all with +90% isopropyl alcohol. Follow this guide. Even so it was written for an Apple iPhone 3G, all the points are still pertinent to your phone as well. While you clean your boards, check for any obvious damage, like burned or missing components etc. When it is properly cleaned, replace the battery. All these steps are to avoid delayed failure caused by corrosion. Best thing to do would be to clean it with an ultrasonic cleaner, but if you do not have access to one, this will at least help. Once all this is done, reassemble your phone and reevaluate. Until it is cleaned, everything will only be a guess. Even with all this, water damage has only a small chance to be fully repaired, but at least you can give it a try.
If this all sounds like it is too much for your skills etc., consider sending your phone to board repairers that have specialized on water damage.
Translation
No podrá recuperar ningún archivo de su teléfono a menos que consiga arrancarlo. Arrancarlo en las condiciones en las que se encuentra causará más daños. Mi colega tiene toda la razón, esto no es una reparación fácil y no hay soluciones fáciles para ello. Mi respuesta es sólo otra opción a considerar.
Por ahora, deje de intentar cargar, sincronizar o utilizar el teléfono. Esto puede empeorar la situación y dañar aún más el teléfono.
Lo siguiente que debes hacer es limpiarlo. Desmonte su teléfono usando Samsung Galaxy S21 Ultra estas guías . Debe quitar todos los escudos EMI. Si no los quitas, es mejor que no hagas nada. Después de quitarlos, limpie todas las placas Placa base y placa de carga, conectores y todo con +90% de alcohol isopropílico. Sigue https://es.ifixit.com/Gu%C3%ADa/Reparaci... . A pesar de que fue escrito para un iPhone 3G de Apple, todos los puntos siguen siendo pertinentes a su teléfono también. Mientras limpias las placas, comprueba que no haya daños evidentes, como componentes quemados o que falten, etc. Cuando esté bien limpia, sustituye la batería. Todos estos pasos son para evitar el fallo retardado causado por la corrosión. Lo mejor sería limpiarlo con un limpiador ultrasónico, pero si no tienes acceso a uno, esto al menos te ayudará. Una vez hecho esto, vuelva a montar el teléfono y evalúelo de nuevo. Hasta que no se limpie, todo serán suposiciones. Incluso con todo esto, los daños causados por el agua sólo tienen una pequeña posibilidad de ser reparados por completo, pero al menos puedes intentarlo.
Si todo esto te parece demasiado para tus habilidades, etc., considera la posibilidad de enviar tu teléfono a reparadores especializados en daños causados por el agua.
Ultimas 24 horas: 0
Ultimos 7 días: 1
Ultimos 30 días: 6
Todo El Tiempo: 50
