Power button is not working
Es esta una buena pregunta?
Hi Sushil,
Assuming you've exhausted all the possible software remedies (reset/wipe/restore/etc.) then there are only about two other things that can go wrong with the power button. There is the actual physical button you put your finger on and push, and under that is the electro-mechanical part consisting of a circuit board with a domed metal contact that makes the electrical connection when the button is pushed.
Either part can cause problems, but fortunately both are replaceable. Here's a guide showing you how to replace the circuit board.
Manuales / Nokia 3 / Side push buttons
There's a different guide just for the physical buttons here.
Manuales / Nokia 3 / Volume and power keys
The parts themselves are readily available; for example here's the circuit board.
Fue útil esta respuesta?
Well check out this video: https://www.youtube.com/watch?v=Ks4TWFuP...
Ultimas 24 horas: 1
Ultimos 7 días: 3
Ultimos 30 días: 3
Todo El Tiempo: 71
1 comentario
- de Nokia
