Replacing Touch Screen on Life Fitness 95X
My touchscreen broke on my Life Fitness 95X elliptical. I was able to order a replacement on AliExpress, however to install it I need to remove the old one first and reattach it to the bracket.
The old touchscreen component appears to have a strong adhesive to a metal frame. What do you suggest I use to remove the glass and then what should I use to reattach it?
This is the original screen attached to the frame :
This is the replacement touchscreen, which is just the glass panel:
Es esta una buena pregunta?
Puntuación
0
@jasongurwin What adhesive removers have you tried? I would start by trying Isopropyl (Rubbing) Alcohol and gently trying to pry the frame out. If that doesn't work, you can use acetone, but be careful.
- de Andrew S
