Saltar al contenido principal
Why my laptop is not charging?
Whenever I open my laptop it doesn't show anything on the screen even it didn't open, as I plugin the charger my laptop open immediately and show me a warning message about power adapt. Is this a battery problem or my power charging adapter is weak?
Contesta esta pregunta Yo también tengo este problema
Es esta una buena pregunta?
Puntuación 0
Agregar un comentario
1 Respuesta
Respuesta Más Útil
@arz64bs Older Dell laptops have a little pin in the charger tip that makes contact with the charging port to determine wattage.
If the pin is bent or missing, the wattage cannot be determined and the battery will not charge.
Visually inspect the charger tip and if the tip is bent, carefully bend it back (while the charger is unplugged on both ends and with a non-metal object).
If the tip is broken, it usually will be cheaper to buy a used charger than fix it.
Fue útil esta respuesta?
Puntuación 1
Añadir tu respuesta
Arz64 -BS estará eternamente agradecido.
Ver Estadísticas:
Ultimas 24 horas: 0
Ultimos 7 días: 0
Ultimos 30 días: 10
Todo El Tiempo: 115
